how necesary is the racing fuel pump and electric water pump?
Old Oct 29, 2006 | 02:53 PM
camarohg's Avatar
i have and 94 trans am a4 lt1 in i put it and 467 comp cam stock motor, with 58mm tb, 3.73 gear, trick flow elbow, 1.6 gm roller rockers, all the exhaust hooker (long tube, y-pipe and catback) k&n filter, crane multispark, 2400 stall converter with a trans go, edelbrock torque arm, programin pcm, ported head, and i`m planing find more power so what you think i need to put electric water pump and fuel racing pump????
Old Oct 29, 2006 | 03:24 PM
MeanGreen97Z's Avatar
A better fuel pump is what im doing now...
EWP is always a place for a bit more power. I'd say your best bet is a dyno tune.
Old Oct 29, 2006 | 03:29 PM
2000GTP's Avatar
The electric water pump is a great dyno proven mod. As for the fuel pump, unless your stock pump is going south, it probably isn't necessary. The Racetronix 255lph pump is a drop in unit that is a good upgrade over the stocker and it runs around 140 bucks.
Old Oct 29, 2006 | 04:22 PM
With the mods you have listed (you don't list larger injectors), the stock fuel pump should be fine. And an electric water pump isn't something you HAVE to do.... its optional. Many of us have chosen to keep the stock water pump on fairly high HP applications.
Old Oct 30, 2006 | 12:12 PM
camarohg's Avatar
yes the car has 30lb injectors
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Queens94z28
Dec 20, 2014 09:11 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
