How much will a shop charge?
Old Sep 16, 2003 | 08:44 PM
ProjectTranzAm's Avatar
About how much would I be looking to spend if I have a shop install a new cam?
Old Sep 16, 2003 | 08:48 PM
ZDriver96's Avatar
500-700 in labor.
Old Sep 16, 2003 | 08:55 PM
Originally posted by ZDriver96
500-700 in labor.
Should I have them port and polish the heads as well. I was expecting them to charge a little more thatn that.
Old Sep 16, 2003 | 11:01 PM
Dolby109's Avatar
If you got the money, a port and polish is defenantly a good add on to a cam.
Old Sep 16, 2003 | 11:05 PM
PoorMan's Avatar
If you had someone else do the work then I would consider having parts changed out that are going to be taken off anyway. Like the water pump, opti, and timing chain, or possible new lifters. That's only if they are high milage and have never been changed before though. If so, then do some of that and change the heads later.
Jeff D.
Old Sep 16, 2003 | 11:09 PM
Originally posted by PoorMan
If you had someone else to the work then I would consider having parts changed out that are going to be taken off anyway. Like the water pump, opti, and timing chain. That's only if they are high milage and have never been changed before though.
Jeff D.
75,000 with stock water pump and opti. We will see what the shop has to say about the timing chain when installing the new cam and head porting. I will wait for the pump and opti to go out before replacement. "If it aint broke don't fix it"
Old Sep 16, 2003 | 11:12 PM
97bowtie's Avatar
I have heard of shops charging $800-1200. Do it yourself and save a lot of money. It is pretty straight forward as long as you have a good set of tools.
RUENUF
Mar 13, 2016 03:37 PM
cmsmith
Sep 14, 2015 09:25 PM
WPHIG2
Aug 27, 2015 06:37 AM
Mir Hussain
Outside of United States
Aug 8, 2015 07:00 PM
Boss002
Jul 24, 2015 10:47 AM
