How much water does it take to milkshake the oil?
Old Feb 2, 2005 | 11:15 PM
Mullet Z28's Avatar
I know that this is a strange question, but how much water or coolant does it take to milkshake the oil enough to turn it brown? I had a problem with my headstuds leaking and ran some K&W Block Sealer through it. I haven't checked under the valvecovers yet, but the outside studs (the ones under the headers) aren't leaking anymore. Also, the motor doesn't overheat anymore either. So far so good.
When I drained the oil, it was black as it should be, but it seemed a little watered down. The rear main seal was still leaking pretty badly too. To make a long story short, is it possible for water to get in the oil and NOT turn it brown? I'm wondering if the studs are still leaking, or if I'm just being paranoid. I'm running straight water and no coolant in the cooling system right now if that matters.
Old Feb 3, 2005 | 12:24 AM
bski224's Avatar
Re: How much water does it take to milkshake the oil?
Hate to say this but could it possibly be your head gaskets?? Just a grim thought GOOD LUCK!!
Old Feb 3, 2005 | 09:34 AM
Mullet Z28's Avatar
I seriously doubt it's the head gaskets because:
1) They're brand new
2) There's no white smoke coming out the tailpipes
3) I've actually seen the coolant seeping out the headstuds.
Old Feb 3, 2005 | 09:50 AM
WS Sick's Avatar
It would take about a 1/4 cupof fluid to do it, the smaller amounts would evap out and you'd only have like your valve covers coated with the milkshake and the underside of your intake , I'm talking coated if there is a leak not a patch here or there that would normally be there from condensation.
Old Feb 3, 2005 | 11:18 AM
Mullet Z28's Avatar
So it's safe to say that since the oil is black, if I do have a leak it's minimal?
Old Feb 3, 2005 | 01:23 PM
WS Sick's Avatar
Pretty much, now a gasket can fail other ways as well, like compression into the crankcase etc.
Old Feb 3, 2005 | 01:38 PM
Gripenfelter's Avatar
Did you put a good quality thread sealer on the threads of the head bolts?
Make sure you don't have ANY coolant in your system until you fix the leak. Coolant in the oil will lead to a spun bearing.
Old Feb 3, 2005 | 02:39 PM
Mullet Z28's Avatar
Speaking of compression into the crankcase, I am running some BIG ring gaps because I plan on running a 300 shot of spray. Maybe the moisture I think I'm seeing in the oil is from condensation in the crankcase and the leaks are from the crankcase pressurizing as you suggested? I guess the only way to find out is to run a breather.
HectorM52
Jul 30, 2017 11:46 AM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
Nickster 7
May 1, 2015 09:04 PM
Donwest22
Parts Wanted
Dec 18, 2014 11:10 AM
