FelPro intake manifold gasket part #
Whats the FELPRO part # for the intake manifold gasket... gonna start the bastard this afternoon.... along with that gasket needed, Im gonna get HIGH TEMP COPPER RTV... anything else i should get besides the fuel line tools ?
Keith,
I've done the intake fix and pulled the intake a few times without having to disconnect the fuel lines. Might want to try that before you disconnect them.
Other than what you mentioned, I used some very fine sand paper to remove gasket material from the block and lots of carb cleaner to clean the intake.
I also changed the throttle body gasket and did the throttle body bypass at the same time.
Don't know if this is a Felpro part number, but LS1 speed has the needed gaskets and their part number is: FEL1284
ModdedNerd
Dec 14, 2014 10:28 AM
Jul 4, 2005 05:00 PM
