How much to re-build short block.
Old Mar 19, 2006 | 09:23 PM
TRYTOTEST's Avatar
Does anyone know how much it would be for a machine shop to rebuld my block, its got 130K miles on it and i wanna start fresh for the summer.
I just want a stock rebuild, nothing fancy, Just stock.
Does anyone know roughly how much a machine shop charged to like, bore, hone, deck, boil, cut crank, and balance it? Just the basic stuff for a short block rebuild.
Old Mar 19, 2006 | 09:28 PM
SevenStars's Avatar
Re: How much to re-build short block.
Ive been checking into prices locally for me and i have got estimates for my 94z ranging from 1500 (smaller shops) to 2200+- (larger shops like gopher and tristate engines)
As for cutting costs stripping it down to a long block your self and assembling it your self can take 100-200 off the price, at least in my case, hope it helps.
Old Mar 19, 2006 | 09:30 PM
93turbo5oh's Avatar
for a shortblock my guy could do a stock rebuild parts, machine work and everything for about $1200 if we used my shortblock as a core.
Old Mar 19, 2006 | 09:32 PM
TRYTOTEST's Avatar
i am considering it, cause i want to start over, ya know my car had 130K miles on it and it was blown for like 20K of it, and i got some blow by, so i think i gotta rebuild..think so?
Old Mar 19, 2006 | 10:18 PM
kirschman's Avatar
I just got mine done a couple of months ago.
clean block
bore .30 and hone
line bore mains
deck the block
assemble bottom end and degree in cam
install cam bearings and freeze plugs
balance rotating assembly
1000.00 I paid cash, think that helped some
I also got my rotating ***. from them; eagle steel crank,I beam rods,SRP flat tops,rings and clevite bearings and a nice cloyes true roller t/c for 1040.00..they knocked some off for me paying cash again
Old Mar 21, 2006 | 10:03 AM
Eric@Victory Racing's Avatar
VRE 355LT1 Economy Shortblock-$2999.99 NO Core Charge
-Eagle 3.480” stroke Cast Crankshaft, Eagle H-Beam Connecting Rods, SRP Pistons, Perfect Circle Rings, Clevite Main Bearings, Clevite Rod Bearings , Clevite Cam Bearings, ARP Main Studs
VRE 383LT1 Economy Shortblock-$3199.99 NO Core Charge
-Eagle 3.750” Cast Crankshaft, Eagle H- Beam Connecting Rods, SRP Pistons Perfect Circle Rings, Clevite Main Bearings, Clevite Rod Bearings, Clevite Cam Bearings, ARP Main Studs
VRE 355LT1 Racer Shortblock-$3290.00 NO Core Charge
-Eagle 3.480” stroke 4340 Crankshaft, Eagle H-Beam Connecting Rods, SRP Pistons, Perfect Circle Rings, Clevite Main Bearings, Clevite Rod Bearings, Clevite Cam Bearings, ARP Main Studs
VRE 383LT1 Racer Shortblock-$3415.00 NO Core Charge
-Eagle 3.750” stroke 4340 Crankshaft, Eagle H-Beam Connecting Rods, SRP Pistons, Perfect Circle Rings , Clevite Main Bearings, Clevite Rod Bearings , Clevite Cam Bearings, ARP Main Studs
VRE 396LT1 Racer Shortblock-$3490.00 NO Core Charge
-Eagle 3.875” stroke 4340 Crankshaft, Eagle H-Beam Connecting Rods, SRP Pistons, Perfect Circle Rings, Clevite Main Bearings, Clevite Rod Bearings , Clevite Cam Bearings, ARP Main Studs
Old Mar 21, 2006 | 10:22 AM
97WS6NY's Avatar
^---That's what I would do, save a little more money, and get a built block from victory. That way when you decide you wanna start getting wild, you already know you have a quality bottom end. No sense in doing something twice. Plus you have a S/C, why not have victory build you a low compression motor, and crank up the boost. I think that is the way to go.
Old Mar 21, 2006 | 06:42 PM
mickeyiz28's Avatar
clean block
bore .30 and hone
line bore mains
deck the block
Hey kirschman, where did u get that work done at in ky because i will know where to go here when my motor goes out
Old Mar 21, 2006 | 07:57 PM
sc1twntrbo's Avatar
cheapest price for a shortblock i have been quoted was 750 for a stock rebuild
Jeff1904
Jun 5, 2016 05:00 PM
68camaroboltz
Oct 5, 2015 11:56 PM
68camaroboltz
Oct 5, 2015 01:46 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
heus
Sep 8, 2015 12:01 PM
