How much pwr an ACdelco opti can handle?
Old Jun 15, 2007 | 01:01 PM
clcam97's Avatar
I just replace my opti with a new ACdelco unit,i was just wondering how much HP can handle safely before blowing up?its also better than the accel right?
Old Jun 15, 2007 | 01:02 PM
clcam97's Avatar
Sorry i forgot,its a 97z28,6m
Old Jun 15, 2007 | 01:03 PM
CrazyLT1's Avatar
How much horsepower are you making?
AC Delco opti's can handle A LOT
Old Jun 15, 2007 | 01:04 PM
CrazyLT1's Avatar
It also depends on how many RPM's you are spinning to and what ignition system you have....
Old Jun 15, 2007 | 01:20 PM
clcam97's Avatar
about 300rwhp only bolt ons,i only rev at 5700rpm. My goal its 500hp
Old Jun 15, 2007 | 02:03 PM
CrazyLT1's Avatar
AC delco will be more than adequate for your application
I am making around 550 RWHP with my AC delco without any problems
Old Jun 15, 2007 | 03:17 PM
It's not an issue of HP, but RPMs. 5700 is not enough to bother it.
BTW, moderators really dislike seeing the same post in multiple forums... http://64.65.63.61/forums/showthread.php?t=526702
Old Jun 15, 2007 | 03:36 PM
clcam97's Avatar
Thanks for the info.I also got the accel coil that makes 48000volts and taylor 8mm wires.Eventually i want to do the LE3 CAM and forged assembly,also a supercharger,i've got $5000 to spend but i want save a little bit more
Old Jun 15, 2007 | 03:38 PM
clcam97's Avatar
Oh yeah and sorry about that,i was going to errase it before i post it,i know its annoying
Old Jun 17, 2007 | 12:56 AM
Compstall's Avatar
Right along w/ Shoebox, don't worry about the HP. From what I've read over the years, ~6,800-7,000 rpm is about the limit before you start to run into problems.
Old Jun 17, 2007 | 12:11 PM
I've seen the optical section support 8,000 RPM and 1,125 HP.
Old Jun 17, 2007 | 12:13 PM
Compstall's Avatar
So I'm on the safe side....
Old Jun 17, 2007 | 01:57 PM
tnmotown's Avatar
you should be safe the the opti. I put in a new ACdelco opti along with a new AC coil and have MSD wires.
Mods are in my sig and have spun the motor to 7K without any issues so far..
Old Jun 17, 2007 | 04:43 PM
clcam97's Avatar
sounds like i made a good choice with the ACdelco opti.Hey tnmotown you have any times with ur current set up?
Old Jun 17, 2007 | 06:04 PM
tnmotown's Avatar
no i havent taken it to the track yet. Before the tranny went though, i did beat a Lambo, Cobra, my brothers '01 Z06, and some others cars that were a waste of my gas. July 11th a bunch of my friends and I are going to Sacramento raceway to get some times. Want to dynotune it before though
