How much power will I be putting down ??? (ordering parts today)
Old Nov 30, 2004 | 12:59 PM
AZ2ENVY's Avatar
I need to know what kind of power I will be putting to the wheels ? I
just took out a loan so I am doing it all at once and doing it right .
Heres what I am ordering.......................
396 LT1 rotating assembly
LT1 assembled trickflow heads
CSI electric waterpump
STS remote mount turbo kit...... www.ststurbo.com
Boost controller from sts turbo
CC306 114 LSA camshaft
cloyes double roller timing chain
New optispark
New MSD wires
New NGK TR-6 plugs
Port match my intake
Already have 58MM BBK throttle body
Already have MAC headers
COMP CAMS pro-magnum 1.6 roller rockers
COMP CAMS lifters
COMP CAMS hardened pushrods
New oil pump
Computer tuning done by MADZ28
I am doing all the labor myself except for assembling the motor and
port matching the intake and having the exhaust welded.
With all this done how much HP and TQ do you suspect I will be putting
down ? Oh by the way I will be pushing between 5-15 Lbs. of boost
Old Nov 30, 2004 | 01:01 PM
crash4cyl's Avatar
Re: How much power will I be putting down ??? (ordering parts today)
If you're not over 450 it's a waste of money , but my guess would be closer to 500RWHP....that's just a guess, from what I've seen..
BTW, that's a hefty loan....Glad to see you haveing fun with the $$ though
Chris
Old Nov 30, 2004 | 01:15 PM
djfuzzy's Avatar
Holy ****. You wanna grab me a loan for the same setup?
No seriously, I know you do.
You should be pushing at least 500 I would say, if not, then return it all. Most def.
Old Nov 30, 2004 | 01:20 PM
ejfagala's Avatar
I have no idea what those heads flow so it's just a guess. Also what pistons did you get and what is your CR? If the heads flow as well as the AFR 210's then I would think you should be in the 450 RWHP with just motor and 500+ with the boost. That should make crazy TQ as well. I am a little curios about the cam selection considering the car will have boost.
Old Nov 30, 2004 | 01:26 PM
AZ2ENVY's Avatar
Should I go with a tighter LSA ??? Maybe a 112 or 110
Old Nov 30, 2004 | 01:31 PM
Gripenfelter's Avatar
You'd be better off porting the stock LT1 castings. The Trick Flows don't flow that much more unless you port them.
Sent you an email btw.
Old Nov 30, 2004 | 01:33 PM
AZ2ENVY's Avatar
Really . I'll just have the stock castings ported and polished with 2.02
and 1.60 valves. That way I can put the money towards other parts
Old Nov 30, 2004 | 06:11 PM
ChevyTuffD.A.'s Avatar
Are u saying that the turbo is only gonna had 50rwhp over N/A???
Old Nov 30, 2004 | 06:32 PM
Tony Danza's Avatar
Check your cam choice there, if I went turbo I'd be getting a custom cam for a turbo set up, not a off the shelf N/A. Also, concidering that this will be a boosted engine, its rare that people choose it to go on a 396 due to the lack of strength between cylenders with the type of stress this engine is gonna take.
Doin up to 15lbs on a 355, you'll have more than enough tourque for the street anyway, the extra cubes may not be that nessesary. You said your doin it right the first time, well man, are you sure your not doing this as a 396+real mount turbo for novalty?
Edit/Addition: Oh yea, I forgot to mention that I remember reading at one point that it is relativly hard to get low enough compression ratios for a 396
Old Nov 30, 2004 | 06:46 PM
Heatmaker's Avatar
Advanced Member
Damn!!!
You took out a loan for all that....
Sucks to be a car enthusiest doesn't it???....
.... something all of us on here can understand....
That will be one hell of a monster though... but why do 396 STS? I thought the stroker guys want higher compression on that setup... isn't the 396 kind of an ALL MOTOR theme?
Why not go 355 low compression and a Giant turbo or TTkit... it will run you about the same when all is said and done...and even still you could puff on the nitrous if that's not enough for you. I'm planning and been planning on the 355-T setup and slowly getting there.
You should do somemore research first before you go blowing cash... figure out what HP figures your looking for... figure out what Head setup and cam will best go for your ideal setup... and then put all the goodies together.
Old Dec 2, 2004 | 11:57 AM
"White Knight"'s Avatar
I say the 396 is a good idea....the extra cubes will help when you start focing the air in there Go 396, you won't regret it
Old Dec 2, 2004 | 12:16 PM
amean94ta's Avatar
you wont be able to use the stock heads and run a turbo. unless you call up cometic and order some very thick head gaskets. you want 10.5:1 compression run 15lbs of boost. also get a custom cam call bullet cams they will set you straight
Old Dec 2, 2004 | 12:28 PM
turbo_Z's Avatar
With 15lbs of boost you should be around 600rwhp at least Id imagine. I dont know about your head choice though. If it was my motor Id be giving Phil at AI a call and asking him about cams too since he can match one to those heads for your application. Spare no expense on the topend as thats were all the power is. You do realize you will have about as much money in that motor than it would take to buy a really nice 97-00 C5 right?
Old Dec 2, 2004 | 05:40 PM
Heatmaker's Avatar
Advanced Member
If I were you I'd do the Camaro delete..C5 add on mode.
Old Dec 2, 2004 | 06:19 PM
amean94ta's Avatar
but then he would be another kid in a high 12 sec vette
