how much power will this give me?
hey guys, this is my stituation. i blew a head gasket oso i pulled the heads off. i have impala head gaskets and while the heads are off i decided to put 2.02 1.60 valves heavy duty stprings and 1.6 rr. what kind of gains can i expect from this
thanks.
thanks.
install an LT4 knock module to accomodate the added noise from the RR.
i would thinnk bigger valves, and rr, with a thinner gasket should give you in the neighborhood of 20-25hp
while they were off you should have had them ported a little...see even more gains
so i will have to deal with what i got. agin thanks tho for the responses.
