How much power should my 355 handle?
Old Jan 28, 2004 | 08:47 AM
xxsaint69x's Avatar
Hey guys, just finishing up my 355.
Stock crank, stock reconditioned rods with arp bolts, trw froged pistons, speed pro rings gapped for n2o. C77H bearings. Ported Canfield heads, CC306, electric water pump etc etc etc. Compression will be slightly lower then stock as the heads are 56.6cc.
Just wondering how much N20 can i spray on top of the heads/cam.
Marcin
Old Jan 28, 2004 | 08:56 AM
bradpreece95z28's Avatar
I would go about a 200 shot or so. Is this a dp kit or a wet kit?
also, I sprayed a 150 shot on a stock internal lt1 for a long time before I tore it down. when I had it apart, the only thing that was damaged was the head gasket.
So, at least a 200 with proper fuel system.
Old Jan 28, 2004 | 04:52 PM
xxsaint69x's Avatar
its going to be a wet shot
Old Jan 29, 2004 | 03:04 AM
mastrdrver's Avatar
I thought Canfield stop making LT1 heads?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
InfernalVortex
Jan 17, 2015 09:35 AM
XtremeLt1
Sep 13, 2002 08:50 PM
