How much power should this combo make?
Old Mar 26, 2005 | 09:02 AM
remaxracer45's Avatar
What will a 96 WS6 that has a 2K mile motor with the following make for power and run a 1/4 in?
LT1 stock bore
all smog gone
Z06 MAF
52 mm throttle body and foil
k and n filter
tb bypass
Lloyd Elliot stage 2 heads fererra valves 1.6 rollers molly push rods
XE 233/239 cam
lt4 timing set
obd 1 conversion and tune
hooker ceramic coated long tubes and y pipe slp loudmouth
SVO 30lb injectors
6 speed spec 4 clutch
410 motive gears
Thanks and recommendations to add to this combo will be appreciated
Shawn
Old Mar 26, 2005 | 09:39 AM
Valkyn71's Avatar
Re: How much power should this combo make?
should be close to 380-400 RWHP.
As far as 1/4 times, your going to need a 12bolt and suspension to get the car up to its potential, but it would be capable of low 12s high 11s?
ps- i think the ZO6 MAF is probebly more trouble than they are worth? Lots of guys making big power thru the stock MAF.
Old Mar 26, 2005 | 01:36 PM
thanks for the insight think the same about the rear, next winter
Old Mar 26, 2005 | 04:26 PM
DiabloGT's Avatar
how are the z06 maf's trouble? so you dont even gain any hp from them?
Old Apr 1, 2005 | 10:00 PM
ttt
Old Apr 2, 2005 | 01:24 AM
Deenasty's Avatar
you wont gain anything from one, unless your maxing the stock maf out. Its just like saying, my car runs perfect with 30lb injectors, but I will pick up more power with a 80lb, because it can handle more..
and as for the trouble part, its because its gonna throw off the maf tables in the tune.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
InfernalVortex
Jan 17, 2015 09:35 AM
siguy
Nov 27, 2014 10:07 AM
