how much power can a moser 12bolt hold
Old Jul 22, 2003 | 04:15 PM
zuluman13's Avatar
As subject says.
how much power can a moser 12bolt hold while running slicks
Old Jul 22, 2003 | 04:32 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Re: how much power can a moser 12bolt hold
Originally posted by zuluman13
As subject says.
depends, how hard are ya hooking
they can cut 1.2 60'fts so i wouldn't be concerned unless yours crazy
Old Jul 22, 2003 | 04:48 PM
KCFormula's Avatar
It depends on a lot of things. Actually Trey, technically our stock rears can hold a 1.2 60' (just not in a 3k lb car. )
Basically unless you are running some huge combo, you won't need to worry about breaking a Moser.
Old Jul 22, 2003 | 04:51 PM
95TA8280's Avatar
The question should be reworded "what 60 ft can...."
Some people are cutting 1.6s with them fine.
Rear ends don't die because of power. They die because of good, hard launches.
zuluman13's Avatar
can it hold like 700 hp im not saying ill put out that much necessarily but just to know
Old Jul 22, 2003 | 04:57 PM
Jeff Belloma
Guest
Posts: n/a
you shouldn't worry. there are a number of guys putting 1000 plus HP through them 10 times or better a weekend. with good axles, they should hold up behind most any street car.
JB
Old Jul 22, 2003 | 05:42 PM
rskrause's Avatar
Moderator
No problems with mine over 2 seasons. 4,000+ lbs, 700+ rwhp.
Rich Krause
Old Jul 22, 2003 | 07:47 PM
treyZ28's Avatar
Rich Krause
i was just about to say "rich was running 700+ rwhp in a t-56 none the less and did just fine"... ohh well
you stink,
trey
F'n1996Z28SS
Aug 23, 2023 11:19 PM
ddr698
Jan 9, 2015 10:05 AM
XtremeLt1
Sep 13, 2002 08:50 PM
