How much power can be made with normal aspiration?
Old Jun 10, 2003 | 02:13 AM
Ghettoraid's Avatar
First, skim this if you haven't seen it already... http://web.camaross.com/forums/showt...8&goto=newpost
I'm starting off with a high mileage 95-97 (california, so theyre obd2) Plan is to rebuild the motor, and either prepare it for supercharging, or just give it some more power right then.
Because reliability is a huge issue for me, I was thinking that going all motor would be wise... I don't street race, just like trouncing the occasional unsuspecting fellow ricer on the freeway, but I mostly just like enjoying my cars in solitude/not competing with anyone but myself/my abilities. So making huge hp, hitting 11's is not really important.
Besides which, forced induction generally adds quite a bit of complexity... (especially turbo).. which is not a good thing if I'm looking for a reliable, long lasting lt1.
So how do people go about this? Higher compression, LT4 heads, cam, roller rockers, pcm flashing, 56mm tb, aluminum u/d pulleys, port+polish...what else..
What parts, SPECIFICALLY would I want for this? (I mean specific brands/specific parts)
Which parts SHOULD I have prior to the rebuild, which parts can I get away with piling on after the fact?
Keep in mind, this is not a track/strip/weekend cruiser, this is my daily driver. I like the out of control rumble of and offset cam, but it needs to be easy enough on the engine that it won't break down every 50 miles... Heh. Don't need to include exhaust, transmission, rear end issues, I'll worry about that later. just focus on the motor.
What hp could I expect if I remained in those^ parameters?
.. am I just better off going with the s/c in the long run? I'll definitely
thanks in advance!!! (this forum has been great so far!)
If there's an FAQ/guide on this, pls direct me!
Old Jun 10, 2003 | 02:21 AM
scoobysnax83's Avatar
I honestly haven't really started yet with my horsepower rebuild , but I just wanted to add that you live in Cali (still) so if you want to remain street legal its gonna limit your options a lot.... Just keep that in mind.
Old Jun 10, 2003 | 02:51 AM
stevil's Avatar
You need to give us specific goals if you want specific answers on parts and such. Am estimated budget would also be nice...
Do you want 300+ rwhp... compete with LS1 cars? 400+? 500+?
You're doing a rebuild, so that leaves plenty of options. You could stroke it. Lower the compression for boost. Go the nitrous route. Or maybe just do heads and cam. Or combine some of those.
If you don't build up the internals, then that sort of screws upping the power later on, so plan ahead. Sounds like a 383 with nice heads and cam would be right up your alley.
Old Jun 10, 2003 | 02:56 AM
agreed.....
Old Jun 10, 2003 | 03:05 AM
Ghettoraid's Avatar
I've got a hookup for my smogs... if anyone needs a smog in cali I'll help them out... lol
only concern is when a car-smart cop pulls me over and looks under the car/pops my hood. haha.
Old Jun 10, 2003 | 03:07 AM
BUSTED
Ghettoraid's Avatar
400 range would be nice.
I just want to be able to smoke up some big slicks on command, preferrably without retardedly low gearing. (I want Weld Magnum Drag 2's in the back... widest i can fit...and some beefy dot drag tires, only put em on once in a blue moon...) [no, i don't care if this is completely impractical, illegal, stupid, waste of money... its fun!]
Suppose I should just talk to the shop and see what they think, what they can do with my budget... (hasn't really been determined, but I'd like the rebuild to stya somewhat reasonable so I can get it all done sooner)
Old Jun 10, 2003 | 03:10 AM
Ghettoraid's Avatar
BUSTED
i read about some poor *** getting his SR20DET swapped nissan sent to the state ref... just to get it out he'd have to swap it completely back to stock...
no fun!
Old Jun 13, 2003 | 07:34 PM
Ghettoraid's Avatar
has anyone else gone this route?
Old Jun 13, 2003 | 08:05 PM
96Z28TealM6's Avatar
What can the cop do to you if you are using illegal parts for your vehicle? Take the car away? Arrest you? I'm curious
Old Jun 13, 2003 | 08:20 PM
Wild1's Avatar
Depends on the state, in Cali any tampering of emissions is cause for a fine. Depending on the cops mood, it could be a fix-it ticket or up to $10,000.
Old Jun 13, 2003 | 08:25 PM
SS Mark's Avatar
Just to let you know, 95's are OBD1. OBD2 didnt start til 96.
-Mark
Old Jun 13, 2003 | 08:38 PM
hsyr's Avatar
-Mark
But didn't the OBD2 start in 95 in Cali only? Or maybe thats just the dual cat exhast. Anyone know?
Old Jun 13, 2003 | 09:06 PM
Ghettoraid's Avatar
yeah im in cali, and have dealt with fix it tickets before. I'm fully prepared to deal with whatever... I just know that if I go NA, i'll be a lot better off than with my turbo'ed eclipse...(one look under my hood and a cop would probably have it towed on the spot..lol)
I don't street race, this is really the only time when a cop is going to make you pop the hood.
Even if he did pop it, all he could see would be an intake, perhaps larger, shinier throttle body.. beyond that he's clueless as to what i've got other than maybe exhaust. Worst fix-it I got on the eclipse was "modified exhaust" ... I just paid it off and cross my fingers, hope that I don't get nailed for it again. Think it was $110+some other fees. No big deal.
As long as I get my smog reports in every two years, I'm in the clear.
Don't worry about emissions, I'm not!! Just tell me what to get !! lol
Old Jun 13, 2003 | 09:07 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
how much money ya got?
