How much power...
Old Jul 4, 2004 | 11:10 AM
ChrisUlrich's Avatar
How much power...
How power would you need to shred your rear in a 6 speed? I don't launch all to often, but do spin the tires every now and then from a stop.
Old Jul 4, 2004 | 11:17 AM
Somnambulist's Avatar
anything less than a 1.6 60'
Old Jul 4, 2004 | 11:25 AM
Heatmaker's Avatar
Advanced Member
Didn't someone say 400hp last time?
Old Jul 4, 2004 | 11:27 AM
depends on how hard you can launch...
Old Jul 7, 2004 | 09:10 PM
How about on a basically stock everything? You think burning some rubber would do some damage?
Also... when you shred the rear, what actually takes place? A little confused on how that affects your driving and whatnot.
Old Jul 8, 2004 | 10:00 AM
No one?
Old Jul 8, 2004 | 10:23 AM
LT1Squirrel's Avatar
with a stronger than stock clutch its more likely
with stickier tires its more likely
when the rear goes, theres usually some gear breakage and/or splitting of the case or axle tube area
Old Jul 8, 2004 | 06:54 PM
So basically... don't do it that often? Or at all...
I think the has a stock clutch, I have a receipt for the clutch, but everything is a part number. They all start with... GM
The tires are balding, so I guess enjoy them while I can?
Old Jul 8, 2004 | 08:01 PM
JoeliusZ28's Avatar
I dont think theres anything wrong with leaving some stripes now and then, just try and be gentle when doing it... as in dont dump the clutch all at once. Im not saying slip it til the tires break loose, just dont be violent about it.
edit: and for the record, id say its very possible to break the 10 bolt with a stock 6 speed.
Old Jul 8, 2004 | 10:19 PM
CAMZ97's Avatar
whats the use of buying a f-body and not blowing the tires away I just dont get it
Old Jul 8, 2004 | 11:12 PM
So lighting them up is very possible for a broken rear? Man, I just want to spin them!! haha... been VERY afraid to do a nice burnout... damn it!! haha
Old Jul 8, 2004 | 11:37 PM
Dave '97 Z28 M6's Avatar
Running a stock clutch, with street tires, with stock HP, in street conditions (i.e. no grippy launch pad), you can have a lot of fun with the F-body and not break your rearend.
IMHO, it's when you start changing one or more of the above that you begin to stress components closer to the breaking point. I've had a lot of fun with my Z28, along with a few evenings at the drags, and the lil' 7.5" is still holding up. As soon as it breaks, though, I think I'll go with a 12-bolt or 9". Of course, I have other plans too...
If you get a good clutch, drop in a blown 383, and some slicks, that puny 10-bolt probably won't last one night at the strip.
Old Jul 9, 2004 | 12:02 PM
FastWhiteTA's Avatar
Spinning the tires means you aren't putting that much strain on your rear end, so if you are spinning, then you are ok, generally. To this note...
My friend has a 10 bolt, 4.10 rear end, heads/ cam LS1 99 M6, probably done 20 launches on it with ET drags, most in the 1.6-1.7 range, and his is still holding up. Of course, he's probably lucky, but still, it hasn't broken yet!
97ramairta
Feb 19, 2008 06:33 PM
chevyrules85
Oct 19, 2007 02:38 PM
GetaZforgetGT
Nov 6, 2006 07:00 AM
