How much oil in VC?
Old Dec 18, 2008 | 02:41 PM
twcblackhand6970's Avatar
How much oil in VC?
When the car is warm, how much oil should be in the valve covers at idle? I just saw a picture of some guys heads with his VC off and the top of his heads look like they get a lot more oil than mine. At idle there is a stream of oil touching the springs, but it doesn't go any higher. Is that enough oil?
Old Dec 19, 2008 | 11:15 AM
Z28SORR's Avatar
To many variables and not enough info. For instance, does he have a high volume oil pump, engine mods, etc? In any case, engines with roller cams and rockers don't need as much oil in/on the valve train as solid cam. engines. And generally Chevy's pump a lot more oil to the valve train then other brands. So unless your having problems with valve specific wear I wouldn't worry about it.
Old Dec 21, 2008 | 10:09 AM
JP95ZM6's Avatar
I only have a stream at idle, but as long as each valve is getting wet, I think that is plenty. BTW that is with 60 PSI.
Old Dec 21, 2008 | 04:33 PM
at idle I'm usually about 25psi, but at WOT im at 60psi. I checked after driving around and the top of the head has oil all over it so I'm not worried anymore.
RX Speed Works
Jul 24, 2015 02:25 PM
big_mac421
Jul 13, 2015 03:48 PM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
