How much oil should I use...
Old Jul 27, 2003 | 06:17 PM
96z's Avatar
96z
I was having problems reading the oil on my dipstick but I have a verified 5 quarts in there right now.
I have the stock pan and use the longer AC delco filter. Is the 5 quarts enough?
BTW even with 5 quarts the line is a little less than 1cm above the last hole....
Old Jul 27, 2003 | 06:19 PM
96speed's Avatar
PDM: I use 5.5 with my stock motor and M-301 filter (similar to the AC Delco pf1218).
Old Jul 27, 2003 | 06:41 PM
Patman's Avatar
Arrow
You should be fine with 5 quarts, but I've also run as high as 5.5 with the long filter with no problems.
Old Jul 27, 2003 | 07:28 PM
96z's Avatar
96z
Ok cool, I may just keep the extra oil out for now and see if Im loosing oil anywhere...
Thanks guys.
Old Jul 27, 2003 | 07:37 PM
Joe Bellman's Avatar
Re: How much oil should I use...
After about 2 tanks of gas, check the level of oil again. The oil will be a little darker making it easier to read.
After I do an oil change, I put 5.5qts in and it is always where it should be.
RX Speed Works
Jul 24, 2015 02:25 PM
big_mac421
Jul 13, 2015 03:48 PM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
