how much oil pressure is too much oil pressure?
Old Dec 22, 2004 | 09:17 PM
nonojoe66's Avatar
ok when the car is started cold since its been cold out it seems to have high oil pressure, just wondering what the highest the oil pressure should safely read at idle cold is... and also what could be the cause?
Old Dec 22, 2004 | 09:21 PM
jchevy's Avatar
Re: how much oil pressure is too much oil pressure?
The oil is thicker when its cold so it shows more pressure, not sure how much is to much, but you are probably fine.
94zLT1's Avatar
as long as it drops as it warms u should b fine...u should see 40-50 when fully warmed depending on the viscosity
mine goes as follows...45 when cold at all times
20-25 at idle warmed and 40 at all rpms warmed
but if ur seeing llike 60 at cold startup thats ok
Old Dec 22, 2004 | 09:34 PM
nonojoe66's Avatar
well when its cold it sits at like the second line from the top... lol idk what pressure that is i think its 60 but im not in my car so idk for sure... i just wanted to make sure thats ok cuz i have some plans for that motor and since it jus wanna make sure its in ok shape cuz its got 111000 mi on it and i got the money for either rebuild or vortech
Old Dec 22, 2004 | 10:11 PM
Mike94ZLT1's Avatar
I would avoid the vortech if your car has that many miles on it...
HectorM52
Jul 30, 2017 11:46 AM
Nickster 7
May 1, 2015 09:04 PM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
captcorvette
Mar 7, 2015 12:37 PM
