How Much Oil Do I need to buy?
Old Feb 19, 2004 | 06:29 PM
TobyZ28's Avatar
i've done a few oil changes using around 5 Litres of oil (roughly 5 quarts). I'm using the larger ACDelco Oil Filter From GM. Exactly how much oil should I put in the car (Assume i don't prefill the oil filter).
1995 Z28 A4 Stock Engine with Bigger Oil filter...
Edit: Thats the ACDelco PF-35C
Old Feb 19, 2004 | 06:35 PM
93midnightta's Avatar
it takes about 5.25-5.5qts depending on if you have a cooler or not. just fill it with five and then check the dipstick when your adding the rest. btw...always prefill your filter. you don't want to have any dry secitions in the loop on your first startup.
Kryckter's Avatar
5.5 qt.
Old Feb 20, 2004 | 05:44 AM
Patman's Avatar
I use 5L (5.3qt) with the long K&N HP3002 filter.
SpeedJunkee
Apr 23, 2015 09:51 AM
transam_388
Mar 15, 2015 11:53 AM
carl.froehlich
Mar 13, 2015 12:38 AM
Queens94z28
Dec 20, 2014 09:11 PM
