How much to offer for this LT1
Old Jan 21, 2006 | 07:43 PM
TheNuge876's Avatar
I have the opportunity to purchase an LT1 for a rebuild. It has everything pretty much except accessories (has an oil pan and intake otherwise just a longblock). Crank and Rods are pretty much new.
Problem is that when the engine was supercharged it damaged two of the pistons and the cylinder walls need to be bored out, it only has a few thousand miles on it. What should I offer for this engine?
Old Jan 21, 2006 | 07:44 PM
95 WHITE TRANS's Avatar
Re: How much to offer for this LT1
500.00
Old Jan 21, 2006 | 07:54 PM
TheNuge876's Avatar
I forgot to mention too that the supercharger is no longer on the engine if that is going to alter the price at all.
Old Jan 21, 2006 | 08:00 PM
Evil Eric's Avatar
Dang, I picked up a spare longblock for my rebuild for 200.00, only had 50k miles on it.
Old Jan 21, 2006 | 08:35 PM
Birdman7389's Avatar
Stock internals? I say 250....did those pistons come apart and chew up bearings or the heads?
Old Jan 21, 2006 | 08:43 PM
TheNuge876's Avatar
I believe the pistons started to overheat because the engine was running really lean due to a bad FPR. Only a small part of the piston was damaged. A machine shop said that all that needed to be done was to rebore the cylinders and then rebuilt but the rest of the internals and heads were still ok.
Old Jan 21, 2006 | 10:30 PM
96capricemgr's Avatar
I paid $550 for a good longblock which I have put 55K on and cammed since. For a blown motor I would say $250 with the intake and such, maybe more if the heads had been ported.
oldschool
Feb 9, 2016 09:21 PM
Noer
Feb 28, 2015 11:29 AM
Roadie
Feb 16, 2015 10:34 AM
siguy
Nov 27, 2014 10:07 AM
