how much lift?
how much lift?
How much lift can a have with stock bottom end without having clearance issues.I am thinking of running 1.7 rockers with my xe 224/230 cam. The lift numbers with 1.5 rockers are .503/.510
Thanks!
Rob.
Thanks!
Rob.
Stock bottom end LT1s can take around or over 600 lift in most cases. Lift plays a smaller roll in PTV clearance than duration does though.
The only acurate way to know if you will have clearance issues is by checking when installing the rockers.
This would also be best discussed in LT1 Tech, moving.
RUENUF
Mar 13, 2016 03:37 PM
