How much HP /w this 383
Old Mar 20, 2003 | 07:18 PM
  #16
Kreinmc's Avatar
Originally posted by Mindgame
Again, how do you know that that's the actual compression? Kinda tough to go that low with an LT1 stroker and flat-tops. What pistons? Any block decking?
-Mindgame
Anyone ever tell you that you have a very odd name?
Old Mar 20, 2003 | 07:20 PM
  #17
gb95zconv's Avatar
-Mindgame
Good point....the compression specs for pistons are given at 0 deck hight. With the standard SRP flattops that I am using along with block decking and stock GM gaskets (.042) and with my 68cc chambers gives me right at 11:1. I would think your compression would be at least 10.5:1 with flatops.
Old Mar 20, 2003 | 07:34 PM
  #18
gb95zconv's Avatar
Originally posted by 95TA8280
What compression do you suggest? I would probably change the cam to on step higher, but like you said I need emissions. I would also prolly go with bigger injectors.
Well between 10.5:1 and 11:1, but like was stated earlier....you should be in that range with flattop pistons and stock head gaskets. Do you know your chamber size?
As far as the cam goes....I cant garantee that the 224/230 will pass. Im not concerned because I know it will be close and I can make it pass with Tunercat if I have to I know the cc305 will pass and its 220/230 but thats not much different from the hotcam. Again , the hotcam will suffice .
Do the bigger injectors....36# if you can afford them but the 30# should work for ya.
Old Mar 20, 2003 | 07:39 PM
  #19
Mindgame's Avatar
Red face
Yep.... of course that's not my real name, just a name I picked up somewhere back in the late 70's before the Apple Mafia and all those other little spin-off groups came along. Back in the days when a modem was considered high-tech candy for the few who had them.
If you have no idea what I'm talking about then don't worry, we'll just leave it at..... yeah, that's a strange screename.
-Mindgame
Old Mar 20, 2003 | 08:32 PM
  #20
4drLT4's Avatar
-Mindgame
Old Mar 20, 2003 | 09:14 PM
  #21
95TA8280's Avatar
Originally posted by treyZ28
IF YOU DONT MIND me asking-
how much?
forged?
billet?
cast?
$3500....I'll find out the rest of the answer shortly.......
Old Mar 20, 2003 | 10:56 PM
  #22
95TA8280's Avatar
64cc
hypertectic
cast crank
stock rods
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
smoknta
Aug 27, 2015 05:07 PM
alphaauto
Jul 26, 2015 04:40 PM
