How much HP/TQ gain from mail order tune?
Old May 19, 2010 | 05:18 AM
foxbat's Avatar
Hey all,
Just curious what kinds of performance gains I can expect from a mail order tune on a bolt-on 94 LT1? Mods:
Cold Air
Tb Bypass
1.6 rr and LT4 valve springs
Mac Headers and Y
High Flow Cat
Full Cat-back exhaust
LT4 knock module
Old May 19, 2010 | 10:23 AM
camaronutt's Avatar
try a search. I'd say average gain is 15 RWHP and RWTQ. I'm gonna send mine in eventually.
Old May 19, 2010 | 07:09 PM
foxbat's Avatar
yeah, i searched, but could not really find anyone with a combination like mine with dyno numbers after a mail order tune
Old May 19, 2010 | 10:03 PM
camaronutt's Avatar
yeah its kinda tough to match up combos and compare. I think its well worth the money, as i said, I plan on sending mine out very soon for my bolt on combo. my car seems to need some tweaking.
Old May 19, 2010 | 11:35 PM
SS MPSTR's Avatar
Impossible to determine.
Old May 20, 2010 | 02:52 AM
Procharged94Lt1's Avatar
Nobody can say xx hp and xx tq. Every car is different and will respond differently.
In addition to the hp I would say driveability and engine/tranny (autos) behavior is improved a lot.
I know its not an apples comparison but I had a mail-order tune done for my Silverado 6.0 V-max and its a night/day difference in how it acts and drives. Well worth the money.
Old May 20, 2010 | 10:03 PM
foxbat's Avatar
i jost got my tuned pcm back from solomon and so far it feels a bit smoother and bites a bit harder. hp/tq gain, i have no idea, but i guess for the small amount of money it's a pretty good thing to do.
Old May 21, 2010 | 11:24 AM
Slick-Z's Avatar
The 1.6 rr will give a little top end power with a factory set up maybe about five horses
The valve springs will allow you to have more lift but will not affect power unless your old ones were in bad shape then you will see a difference.
COI is good for at least 10 to fifteen horses on average
The headers and exhaust will probably give you about ten to fifteen rwhp and the lt4 knock module will probably not be much different with a stock set up other than the roller rockers.
A tune with these should produce about twenty more horses and better fule economy but thats just a guess in the as to about what i got when i had all of your upgrades plus a grenatali mass air sensor and 52mm tb. Doesnt sound bad and id say you should be around the 315 to 320 mark with a good tune.
Old May 21, 2010 | 11:57 AM
slomarao's Avatar
With a good tune I would expect 300-310rwhp, 320-330rwtq.
I have the same mods you do plus a 52 mm TB, crank pulley, ls1 DS, mild head/intake work, cutout. My numbers are in my sig.
If i get a better tune I bet theres 7-8rwhp & 11-12rwtq in it still.
Old May 21, 2010 | 12:05 PM
Slick-Z's Avatar
Possibly i did mean about fwhp for the guy asking the question and yeah your right with a better tune if possible then there is always a little more power. Not bad numbers but with the intake work and mile head work then your going to be getting more power than the guy that is just going with bolt ons and a tune upgrade.
Old May 21, 2010 | 06:11 PM
foxbat's Avatar
slickz/slowmaro: thanks for the input. i think i'd be a bit higher than 320 at the crank, because lt1's are essentially 295-300 crank hp engines if you add corvette type breathing from intake and cat back. add mac headers, y, and hi flow cat, 1.6 rr/springs, tb bypass, tb airfoil, and tune, and i'd estimate at least 25 rwhp combined? i know folks here with mac headers have picked up 20-25 rwhp, so i'd hope i was at least 300 rwhp
Old May 21, 2010 | 08:07 PM
slomarao's Avatar
I'll bet your within 5hp/tq of 310rwhp and 325rwtq, well provided the tune isnt pure crap.
Old May 21, 2010 | 10:17 PM
foxbat's Avatar
that's what i was guesstimating. i think the tune is pretty good - car runs excellent and is certainly smoother. 6th gear is more usable now, less bog/grit than before tune.
DirtyDaveW
Dec 1, 2016 05:37 PM
HarleyZ28
Oct 5, 2015 06:23 AM
grabbem88
Feb 22, 2015 11:16 AM
k1996z28
Jan 21, 2015 07:22 AM
