How much hp are stock rods good for??
Old Mar 27, 2006 | 09:09 PM
hellostop's Avatar
LT1 Looking to build a steel crank, D1sc blower,mild cam, 355, with relatively high compression - may go w/ E85, & 10:1. How much will stock rods take?
Old Mar 28, 2006 | 05:14 AM
LameRandomName's Avatar
Re: How much hp are stock rods good for??
I see everyone is stealing my idea now...
As to the rods, the stock ones are stronger than they get credit for, but I wouldn't use them in that app.
I think GM claims they are good to 450hp and I would be comfortable using them well past 500 (flywheel), BUT... if you do a blown E85 engine and you do it anywhere even NEAR right, you'll be WTF (Way The F___) past the rods limits.
Old Mar 28, 2006 | 08:10 AM
The two stock PM rod failures I've seen documented occured at about 600HP.
Moving to "LT1/LT4 Engine Tech"......
Old Mar 28, 2006 | 08:54 AM
cjmatt's Avatar
Arent the bearings the weak point? How easy would it be to switch to a better set of crank and rod bearings? Then how much could a stock bottom handle?
Old Mar 28, 2006 | 09:22 AM
His question is "stock rods".... and bearings aren't going to make the rods stronger.
Old Mar 28, 2006 | 09:34 AM
TRYTOTEST's Avatar
Are cleavite 77 bearings good?
Old Mar 28, 2006 | 02:25 PM
89TramsAmGTA's Avatar
How about addding ARP rod bolts. Is it the rod bolt that fails first or the rod itself?
Old Mar 28, 2006 | 06:18 PM
12Second3rdgen's Avatar
I looked into that with my PM rods, by the time you buy rod bolts, pay to have them pressed in and resized, you have enough into them to just buy a new set of aftermarket rods and sell the old ones.
Old Mar 28, 2006 | 06:23 PM
LT-7's Avatar
Depending on what your machine shop charges, thats just good enough to buy a set of the Eagle econos. They are only rated to 500 and it wouldn't be an upgrade because then its a lil more for the upgraded rodbolts.
I was going to get new rods, but ended up just getting some ARP rodbolts instead since my machine shop just resized the rods for me for free. If I had to pay around 400 to get the work done, then I would have definatley gotten some better rods, just not the Eagle cheapies.
Old Mar 28, 2006 | 10:07 PM
hellostop's Avatar
Thanks for the feedback!
Any econo recommendations for +- 575hp rods,
ps, how big cc's should head intake ports be on aftermarket heads to flow 575hp on 10psi boost, twin high flow i/c's, 355 lt1? 190,200,210,+
I'm under impression stock or lt4 heads may flex & blow head gaskets.
oldschool
Feb 9, 2016 09:21 PM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
Catmaigne
Dec 25, 2014 12:16 PM
Hurin
Dec 13, 2014 07:38 PM
