How much hp can a 2-bolt main take?
Old Aug 24, 2005 | 07:12 PM
Kurt Crosbie's Avatar
It's god ARP studs and it's a longrod 355 operating at 11.3:1 with forged ross pistons and 6" eagle i-beams.
Old Aug 24, 2005 | 07:57 PM
MachinistOne's Avatar
Re: How much hp can a 2-bolt main take?
You are fine with that combo.
Old Aug 24, 2005 | 07:59 PM
Eff's Avatar
Eff
yep, most people will tell you 500hp. unless you are spaying a big shot you'll be fine.
Old Aug 24, 2005 | 08:41 PM
500fwhp or 500rwhp? Cause I will be upgrading to the Super Vic and 11.7 compression which should bring me to 500rwhp w/a custom grind.
Old Aug 24, 2005 | 08:45 PM
SStrokerAce's Avatar
Part of it is how well the motor is put together... if you have the clearances set right, oil pressure right etc..... everything should be awesome. There is a area where the caps might start to have a problem and start moving around and you are starting to get close to that when you get over 500hp.
Bret
Old Aug 24, 2005 | 08:51 PM
Looks like I'll be pushing the limit if I go with the Super Vic intake then.
Old Aug 24, 2005 | 11:04 PM
What are the specs on the gm847 cam? I didnt know that was capable of 500rwhp??
Old Aug 24, 2005 | 11:05 PM
If you are pushing 500rwhp I would be real worried about 2 bolt stuff.....I assumed you were going to max out at 450.
Old Aug 25, 2005 | 12:33 AM
Silvershark's Avatar
My buddy has a 500 rwhp lt1 and he is running a two bolt main. He hasnt had any problems yet.
Old Aug 25, 2005 | 01:13 AM
FutureZMan's Avatar
Personal Experiance: 550HP, no more.
Old Aug 25, 2005 | 07:14 AM
LameRandomName's Avatar
It's still a small block chevy.
I recall a 355 I built a few years back...
Two bolt main.
I line bored it, had it honed with torque plates, used studs and a forged crank with pink rods and "I don't remember" forged pistons. Good heads for day... Angle plugs.
Ran a Weiand Team-G with a 750 double-pumper and a Comp Cams 305 magnum. Spun that sucker to 7500 on a regular basis
We didn't have dyno rooms next to every Walmart back then, so I can't tell you what kind of power it made, but the point is that two bolt main SBC's with good prep and quality parts will hold together surprisingly well.
Old Aug 25, 2005 | 08:24 AM
Good stuff.
I believe an 847 could make 500rwhp with the right intake and heads, but I'm not going to be sticking with the 847. I will get a custom grind when I get the intake. But I will be sticking with LE3 heads.
Old Aug 25, 2005 | 09:37 PM
500rwhp N/A with the right heads/cam? Tell me more! I have all the boltons you can do with stock casting heads. I am running the LE2 heads with the GM847 Cam. I guess I could have went LE3. :P Anyhow, is this switching to carb or still EFI? My buddies 500tq firebird is making me very jelious!
Old Aug 25, 2005 | 09:49 PM
jerminator96's Avatar
There are a few companies that make a billet aluminum main support that should make your set up stronger than any 4-bolt block. I can't remember where to get them but Badasscars.com (Bad *** racing engines) uses them and they could tell you where to buy one.
Old Aug 25, 2005 | 09:56 PM
96vortechSS's Avatar
My engine is only a studded in two bolt main and I've never had a problem numbers in the sig.
