How much does a fuel pressure regulator cost??
Old Aug 14, 2003 | 04:57 PM
speed76demon's Avatar
and where is a good place to buy one from? also how hard is the install?
Old Aug 14, 2003 | 10:01 PM
Josh-'04 GTO's Avatar
You can get adjustable replacements for anywhere from $65-$120. I'd probably check out www.thunderracing.com or www.tbyrne.com, although I'm sure jegs some choices as well.
Old Aug 15, 2003 | 06:03 PM
how often do they go bad and how do i check it does??
Old Aug 15, 2003 | 06:16 PM
snorkelface's Avatar
I've personally never heard of one going bad. However, hold of a little bit before purchasing one, and do some research. From what I understand, they won't help your car at all in the long run. When you install it, and you adjust your fuel pressure (FP) to the optimum setting, your going to probably feel a good power gain in the beginning. However, over a short period of time, the computer will just learn to compensate for any adjustments you mad mechanically, and return the air-fuel ratio to stock specs. The only way to REALLY change your air fuel ratio would be to have your vehicle's PCM tuned.
Put that $100 to the side, and save up for a dyno tune.
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jul 4, 2005 05:00 PM
F(ast)-body
Feb 26, 2003 09:05 AM
