How much does it cost to rebuild a engine?
Old May 25, 2008 | 02:20 AM
lt1stroker's Avatar
Just like the title says. How much does it cost to rebuilta lt1 engine? I mean every thing from the kit, all the plugs, oil pump, etc?
Old May 25, 2008 | 04:56 AM
96m6lt1's Avatar
That question has some very different answers. Depending on the type of rebuild will determine actual parts,are the pistons reusable,does it need to be bored,has it spun a bearing etc?
you can expect to spend 1800.00 on up at minimum..
Old May 25, 2008 | 12:02 PM
mrmint69's Avatar
If you do the work yourself and do the minumum i guess it shouldn't be to bad. If you only buy stock replacement parts that would be the cheapest route and reuse parts that are in good shape. I replaced a lot more than i had to years ago and it added 25% to the rebuild.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Sergio
Jan 27, 2016 04:27 PM
Not Dave
Dec 11, 2014 06:32 PM
guionM
9
Aug 29, 2002 01:48 PM
