how much can the opti take?
Old Aug 18, 2005 | 07:41 PM
snakethis69's Avatar
i just ranmy car and i noticed that there was a little pool of coolant under it. i also noticed coolant on the opti. . . BRAND NEW ONE. i was wondering how much an opti can take? i DO NOT wanna have to remove this one again and get another. just how much can it take? it wasnt that much coolant and i dont think it drenched the opti. if i let it evap will it be ok? please let it be ok. . .
Old Aug 18, 2005 | 07:49 PM
jasons93z's Avatar
Re: how much can the opti take?
i have washed my engine many times and not had a problem with it. I replaced my opti at about 100k just because it was mising a little and when i took the opti apart there was no sign of water. You should be fine.
Old Aug 18, 2005 | 07:52 PM
awsome thanx
Old Aug 18, 2005 | 10:56 PM
No one can predict how much water will affect a given opti. Too many variables. I drove a few thousand miles with an intermittent water pump leak and it did not affect mine at all.
Old Aug 18, 2005 | 11:07 PM
Cmr0z28's Avatar
Like shoebox said, it really depends on the situation...but since yours is vented, you should probably be okay.
Old Aug 19, 2005 | 12:04 AM
turbo_Z's Avatar
The only opti I have taken appart was sealed really well... only way water or coolant could get inside is if you dropped it in a lake. Power washed my motor a few times and never had any problems as I expected. You should be ok but I would worry more about the leak than the opti.
Old Aug 19, 2005 | 06:43 AM
fixed the leak, piece of gasket left on from cam install, just wanted to make sure that since my opti was wet on all sides and there was a little puddle under the car that it wasnt fried. cause i dont wannad rop another 150 on another opti.
Old Aug 19, 2005 | 07:59 AM
96capricemgr's Avatar
A little dielectric grease on the wiring harness seal goes a long ways towards making the opti even more waterproof. I did that to mine and it has had a few coolant baths since with no ill effects.
Formula Steve
Sep 19, 2023 08:31 AM
94Maroz28
Oct 27, 2015 04:38 PM
Ks0209
Oct 1, 2015 07:32 AM
colts0455
Sep 27, 2015 01:07 PM
jayblev95
Sep 26, 2015 09:44 PM
