Wobbly Belt Tensioner
Old Aug 19, 2005 | 12:44 AM
Z_Maniac's Avatar
Question Wobbly Belt Tensioner
Has anyone ever had their accessory belt drive tensioner squeak like crazy or wobble? Basically I started hearing a squealing noise and sounded like a wobbly wheel bearing or something is what I can explain it the closest to. As I give the car more gas the squealing gets louder so it's definitely coming from the engine.
I then thought it was a noisy fan bearing so I went under the car to listen while the engine was running and I noticed the noise to be coming from the Belt tensioner of the accessory belt drive. I also noticed the belt itself gets off track after a few minutes of running the engine with the noise coming from the tensioner housing. I then noticed what seemed to be a crack or space in the tensioner housing which is what causing it to wobble and possibly cause the belt to be tooth off.
Is this part easily replaced or what could be done to fix it? Any ideas or suggestion would be awesome!
Thanks,
JD
Old Aug 19, 2005 | 08:14 AM
Re: Wobbly Belt Tensioner
Very easy to replace.
95blkss
Sep 22, 2015 03:18 PM
rideordie
Sep 7, 2015 08:22 AM
LazyLemming
Aug 29, 2015 07:36 PM
john henry
Aug 14, 2015 08:33 AM
john henry
Classic Engine Tech
