how much cam can i use?
will any of these cams give me any lope at idle? is the lt4 hot cam too much? how much lift before valve clearance is an issue? im looking to push the limits of drivability i guess.
there are tons of clips on youtube and streetfire, but the hotcam and 503 are going to have the most lope to them for off-the-shelf. the 846 sounds pretty good too tho. stock heads/block ptv clearance is not an issue with any of the cams listed.
cc306, gm847, cc503, lpe 211/219, lpe 219/219, gm846, cc305, LT4 Hot Cam, etc etc etc
imo go with a custom LE cam
he can taylor a cam to your needs and goals, and at $300 shipped for an LE custom cam versus $260+shipping for an off the shelf cam, there is little cost difference
