how much better is the LS1 suspension
Old Mar 3, 2004 | 01:30 PM
z28marine's Avatar
How much of an improvement is the LS1 suspension than the lt1? Will the LS1 shocks stuts and springs work on a 95'?
Old Mar 3, 2004 | 01:44 PM
1msfyter's Avatar
Its all the same suspention , except for the brakes. Ls1's are a bit lighter engine. Why looking at SLP take offs?
Black_Z28's Avatar
The shocks and springs are the same I believe.
Old Mar 3, 2004 | 02:20 PM
z28marine's Avatar
i just saw this on ebay
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2464414867
and wondered if it would be any improvement at all
Old Mar 3, 2004 | 02:32 PM
RE AND CHERYL's Avatar
Cool
While you can use the same shocks on the LS1, you cannot use the springs. The LS1 engine is lighter and the front of your car would sit lower. From what I hear though, the 3.8L guys can swap in LS1 springs as the iron 3.8L and the aluminum LS1 weight about the same.
Old Mar 3, 2004 | 03:02 PM
Black_Z28's Avatar
No it won't really help at all. If your suspension is getting kind of weak then it may be worth it, but it won't be any better than stock. Because it is stock stuff.
Old Mar 3, 2004 | 03:36 PM
If you needed the upper an lower spring seats and related stuff, it might be a decent deal. That is, if all what is pictured is actually included. Otherwise, you can get all that stock take-off stuff from SLP for cheap and it is virtually brand new.
It won't be an improvement over what was stock (because all that stuff is stock equipment).
RUENUF
Mar 13, 2016 03:37 PM
Nickster 7
Aug 27, 2015 10:12 PM
97blackformula
Aug 27, 2015 06:02 PM
force10
Jul 30, 2015 04:56 PM
mrwz28
Jul 8, 2015 09:11 PM
