How much $ to replace my a4 with a m6?
Old Sep 24, 2003 | 12:49 PM
NewbieWar's Avatar
Just like topic says...
how much is it gonna cost me to completly do everything change all the necessary parts put in a clutch and all that stuff...
how much is it gonna run to replace the automatic?
Old Sep 24, 2003 | 01:18 PM
1msfyter's Avatar
$1500 -1700
see post above
Old Sep 24, 2003 | 04:52 PM
CrippleFightin's Avatar
It can vary alot. It all depends on if you take your time and search for parts, or if you just buy a package that comes complete with everything needed. If you search around and get all the parts individually, you could save yourself a significant amount of money.
Old Sep 24, 2003 | 07:24 PM
Fast Caddie's Avatar
I'm changing out mine this weekend and here is a little estimate for ya based on my two month spending spree:
M6 conversion kit- $1500 + $60 for freight
Parts from Jason Cromer
LT4 PP- $211
LT1 disk- $145? (wanted the SLP one for $89, but they were BO'd)
Center console plate w/boot- $45
new trans mount- $45
various connectors/pigtails- $50
shipping ~$20 on the above
Other stuff
get flywheel resurfaced- $30 at NAPA
pilot bushing ~$5
clutch alignment tool ~$10
Pro5.0 shifter w/ custom ****- $230
Strange 3.73s- ~$200
Install kit for gears- $90
grease, fluids, etc -$30
having the gears installed ~$200 (hooked up through a friend)
reprogrammed PCM $45
plus more shipping charges/ taxes
All total... about $2850
I originally budgeted for about $2400, but went a little over due to the shifter and forgetting about the S&H charges. If you have 3.23s and want to do it pretty cheaply(no gears, new clutch/PP, or other things) you MIGHT get away with spending around $2000. But if you want to do it right with a new clutch/PP, gears, good shifter, etc..... plan on spending closer to $3K when done
Yea, some stuff is a little unecessary... but it'll add up quicker than you think even without those things. Trying to drive this car around with the M6 and 2.73s for a few days will be a little interesting too. Looked at a gear calculator and in 6th at 80mph I'll be turning 1400rpm I hope the mechanic my bud is hooking me up with for the gear install can do this thing early next week.
Hope this helps
KYWes
Apr 15, 2015 05:48 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
stopthatman
Feb 9, 2015 09:00 PM
ANDYZ28
Dec 29, 2014 09:13 PM
Hurin
Dec 13, 2014 07:38 PM
