how many of you use MSD blaster coil?
Old Oct 6, 2003 | 11:15 PM
red_warrior_z28's Avatar
have any of you guys used a MSD blaster coil? if so how good are they. what do they help in? what is the difference between that and stock coil.
Old Oct 6, 2003 | 11:47 PM
Compstall's Avatar
Since you're new, I'll take it easy on ya.
I have seen this very question come up 3 times in just the last week.
I have had the Blaster coil in my car since I first bought it back in March '00. It has worked just fine for me. You won't see any difference between that and the stock coil, unless you were able to measure the voltage difference between the two. The stock ignition system in LT1's are pretty good from the factory. The only real reason you might want to upgrade it is if you went to forced induction or N20 to ensure a good spark.
Some people like them, some don't. It's your choice. Good luck.
Old Oct 7, 2003 | 12:48 AM
Rich_z28's Avatar
I've got one. You won't tell a difference with it. The only reason I bought one was because I thought the stock one had gone out and just replaced it with an MSD product.
Old Oct 7, 2003 | 02:45 AM
NVetro's Avatar
I have one, but i also added an MSD 6AL ignition unit. So the car does start up alittle better and the rpms climb alot smoother also.
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
tdigger9899
Sep 7, 2015 10:56 AM
canuck94z28
Aug 19, 2015 05:50 PM
88IROC_Z
Jul 22, 2015 11:38 PM
