how many wires do a temp sensor have i only found one
Old Jun 1, 2009 | 01:21 PM
ghost stripes's Avatar
but the plug has two pronges i hope only one wire
Old Jun 1, 2009 | 01:25 PM
meissen's Avatar
Which temp sensor are you looking at? There's one on the driver's side head and one temp sensor in the water pump.
Courtesy of Shbox -
If it's the temp sensor on the driver's side head, it's only one wire:
http://shbox.com/1/harness7.jpg
If it's the temp sensor on the water pump, it's two (black and yellow):
http://shbox.com/1/harness2.jpg
Old Jun 1, 2009 | 03:15 PM
93zstartedme's Avatar
If it's the one on the cyl. head(for the temp gauge) the sensor itself looks like it has 2 metal prongs, one with a slightly rounded or squared end and one with a pointy end. I think the rounded one is just there for stability and the pointed one is what actually contacts to the one wire connector from the harness. This confused me too. Hope this helps.
Old Jun 1, 2009 | 03:29 PM
thanks it is the one on the head i will hook it up and see what happens thanks guys
HectorM52
Jul 30, 2017 11:46 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
