how many hours to do rocker swap?
Old Jun 27, 2003 | 07:17 PM
MattysTA's Avatar
How long did it take you guys? any tips?
Old Jun 27, 2003 | 07:25 PM
QCKZ28's Avatar
shouldnt take you longer than 3-4 hours, but im not a good person to ask because i dropped a valve
i ended up doing heads/cam while i was into it.
jesse
Old Jun 27, 2003 | 08:32 PM
LT1FlaGuy's Avatar
I just swapped my 1.6's for 1.5's to get them off new ones on adjusting and taking the alt. off and on to get the passanger valve cover off and back on.... took me about 2 hrs total... took some time because the valve cover gaskets " made of rubber" like to come off.... i just used some gasket sealer just to hold the sucker on there for 5 seconds while i put the cover back on.
Old Jun 27, 2003 | 10:29 PM
Timberwolf's Avatar
I think I had a half hour per side tops.
gaskets are the biggest hassle when putting the covers back on
I used some high tach sealant to hold them into the cover. worked MUCH better
Old Jun 27, 2003 | 10:43 PM
MattysTA's Avatar
are those times including changing the springs?
Old Jun 27, 2003 | 10:56 PM
QCKZ28's Avatar
it should take you a few hours to change springs and rockers. i used compressed air and had to remove the headers to get the air fitting in the plug hole. perhaps the TDC method would be quicker?
Old Jun 27, 2003 | 11:01 PM
Timberwolf's Avatar
Not mine. He only asked about rockers though
Old Jun 27, 2003 | 11:02 PM
MattysTA's Avatar
hopefully i wont have to take off my headers to change mine, i have a flexible hose for my air fitting plus i have slp headers so well see i guess. im changing the rockers,springs,seats,retainers,valve seals,studs,adding guide plates,and new locks. i guess itll probably take me like 3-4 hours easy lol
Old Jun 27, 2003 | 11:30 PM
QCKZ28's Avatar
i had the flexible hose too, but i couldnt get it to go straight and i was afraid of ruining the threads...so i just pulled the headers. but your headers may be different than mine, just giving you a heads up. any other questions feel free to shoot me pm.
jesse
Old Jun 27, 2003 | 11:36 PM
MattysTA's Avatar
Thanks for all the replies fellas,hopefully itll go pretty smoooth(yeah right lol)
Old Jun 27, 2003 | 11:49 PM
QCKZ28's Avatar
just dont drop a valve like me but if you do it will be ok just pull them heads gettem ported and put a nice cam it her. im very glad i dropped a valve
jesse
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
