how to make more space (headers) passenger?
Old Aug 26, 2004 | 08:28 PM
NewbieWar's Avatar
how can i give myself more space, remove things and what not?
Old Aug 26, 2004 | 08:37 PM
fesgali's Avatar
Re: how to make more space (headers) passenger?
What exactly are u trying to do?
Old Aug 26, 2004 | 11:02 PM
NewbieWar's Avatar
put my headers in and they dont fit.
ive tried from above and from below... but ive almost got it in the front wont come down...
Old Aug 26, 2004 | 11:13 PM
Loadre's Avatar
Remove the single thru-bolt in the motor mount on the passenger side. Loosen the drivers side one just a tick then jack the motor from the bottom with a piece of wood against the oilpan.
Old Aug 27, 2004 | 12:53 AM
NewbieWar's Avatar
where is that can anyone help me to find it?
Old Aug 27, 2004 | 01:35 AM
disco192's Avatar
what kind of headers are you trying to put in? You can search for a writeup as many have written guides on how to install hookers or other LT headers. MACs can go in from the top as can most shorties.
Old Aug 27, 2004 | 02:28 AM
stik6shift93's Avatar
To get my passenger side flp in I had to put the header flat on the ground with the flange facing up. The collector facing the back of the car so the collector is somewhat under the driver side. Then twist the header so the the forward most part of the flange goes up in space and then just twist it while sliding it up in there. Hard to explain but you dont need to take off the starter or lift the motor up. Just make sure you have the car as high up as possible, i remember it had to be pretty high up on the jackstands.
Old Aug 27, 2004 | 08:25 AM
NewbieWar's Avatar
ive tried all kind of twisting and pushing, and there just isnt the space fore the edlebrock headers on the pass side
Old Aug 27, 2004 | 08:36 AM
fesgali's Avatar
Try removing the starter, the dipstick tube, and then see what else is in the way. Just play with putting it in from different angles.
alex5366
Mar 8, 2015 11:32 AM
alex5366
Feb 17, 2015 10:43 PM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
Jul 4, 2005 05:00 PM
blue89iroc
Jul 26, 2002 04:56 PM
