How to make a flat torque curve?
Old Jan 2, 2004 | 09:50 AM
NewbieWar's Avatar
ok im starting to consider my options for cams and rollers and springs and all the good stuff u mind as well do while ur in the engine.
ive seem several peoples dyno charts on here and it was almost a straight line, what does someone have to do to get it like that?
considering emissions and daily driver
Old Jan 2, 2004 | 12:03 PM
Camaro_Maniac63's Avatar
XE 224/230 should get you what you want and be emissions legal still.
Old Jan 2, 2004 | 08:00 PM
NewbieWar's Avatar
what kinda horsepower will i see w/ this cam?
thats all i need? is the cam?
Old Jan 2, 2004 | 08:35 PM
97WS6SCharged's Avatar
You're also going to need a good set of worked heads (as well as the other usual things like headers, CAI, etc...) to see the full benefit of the cam.
Old Jan 3, 2004 | 09:21 AM
NewbieWar's Avatar
but if i just threw it in there all by its self and got all those things later it would work?
Old Jan 3, 2004 | 11:22 AM
The cam itself w/1.6rr will probably give you ~20-25hp. Yes, you can just put the cam in now and it would work, but if I were you, I would save up my money and do everything at once. The cam itself might disappoint you as far as HP goes, but you do cam + heads + headers at once, and you will have the biggest grin on your face first time you floor the car after all that. Good luck.
Old Jan 3, 2004 | 07:32 PM
NewbieWar's Avatar
hrmm... cam it self will be disapointing? hrmmm
well what are a good set of headers?
advantages? i know some are cheap some sound good some are easy access to plugs...
im looking for probably shorties or mids cause i need smog legal (unless there is a long smog legal ones)
with tax money coming soon i'll have a big chunk of money to work with.
Old Jan 3, 2004 | 07:54 PM
Yeah, just wait for the money to come. Then, a set of Lloyd Elliott heads (~$1000), a set of 94-95 style SLP shorties or MAC shorties (~$500), and the XE 224/230 cam package (~$750) should get you an emissions-legal yet powerful car (This doesn't include installation costs by the way). A guy dynoed 350rwhp/350rwtq with the same setup. Good luck.
Old Jan 3, 2004 | 09:18 PM
Bud M's Avatar
Mac headers are not legal in California. You need a set of headers with a CARB E. O. number. That includes SLP, Hooker shorties, Edelbrocks, BBKs? and a couple of others.
The 224/230 is on the ragged edge of being able to pass smog. Generally the Comp 305 is the most radical cam that will pass smog, and it will require programming.
For a flat torque curve, you don't want a big increase in cam duration anyway. Something like the LPE 211/219 or GM 845. Short duration, more lift.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
canbaufo
May 5, 2015 03:43 PM
Jason Short
Jan 19, 2015 06:34 PM
InfernalVortex
Jan 17, 2015 09:35 AM
