How low will the oil get before the light comes on?
Old Jan 4, 2004 | 12:04 PM
funina91ss's Avatar
Question How low will the oil get before the light comes on?
I have always wanted to know this.
thanks Sean
Old Jan 4, 2004 | 12:09 PM
nateh's Avatar
About one quart below the low line on the dipstick.
Old Jan 5, 2004 | 08:57 AM
IslandZ's Avatar
Next time your changing your oil, fill it up slowly and turn the key to on, when the light goes off, you know how much you put in there, and let us all know then!
Kinda curious myself, so if I change my oil before you do, I will let you know.
Old Jan 5, 2004 | 10:18 AM
Tom R.'s Avatar
Does that mean two quarts below the full mark, or three quarts total in the motor?
Old Jan 5, 2004 | 10:32 AM
Severous01's Avatar
yeah...funny you should ask that one. i lost my rear main seal recently and mine never came on. dont trust dummy lights, always check and check often
Old Jan 5, 2004 | 12:14 PM
DR.ZED's Avatar
The low oil light will not come on when driving.
It only checks when you start the car.
Old Jan 5, 2004 | 01:33 PM
Joe Bellman's Avatar
I check everytime I get gas. What else is there to do....stand there and watch the numbers turn????
Old Jan 6, 2004 | 04:50 PM
Severous01's Avatar
i check mine too, and i check my tires every third time i get gas....
Old Jan 7, 2004 | 09:33 PM
arnie's Avatar
Depends on the rpm of the engine. If idling or low rpm, may need to be 3 qts. down. If reving alot higher, and enuf oil is up top on it's way down, 2 qts. down may do it. BTW, lite should indicate 8-10# of pressure.
transam_388
Mar 15, 2015 11:53 AM
jj71787
Jan 31, 2015 10:20 PM
Jan 23, 2015 01:13 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
siguy
Nov 27, 2014 10:07 AM
