How low can they go?
Old Oct 5, 2003 | 10:24 PM
Rodrigues's Avatar
I found a deal on a 230/236 locally but it has .622/.624 lift with 1.6 rockers which i have.
Supporting mods are:
Ported heads that flow a decent amount more in the .6-.7 range
CM618 springs
Stock lifters
Stock valves
Hardened pushrods
Would it be too much?
Old Oct 5, 2003 | 10:33 PM
nitropatch's Avatar
it might be alittle to much sence you dont have that much head work done and, i beleavet aht that cam might not work because of the lift being to high, you risk the chance of clearence from the pisotns and such, but i would try getting a little smaller cam but i aint possitive on that, if i were you i would call TPIS and ask them because they know the make lift and stuff like that .
Old Oct 5, 2003 | 10:45 PM
Rodrigues's Avatar
The porting is fairly extensive and the heads could handle the extra flow at the higher lift but could it handle it physically, thats the main question. Is anyone else running this much lift on stock pistons/heads?
Old Oct 5, 2003 | 11:06 PM
Rodrigues's Avatar
What springs could handle it?
Originally posted by Slow95car
buy it if you like lots of coil bind
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
68camaroboltz
Oct 5, 2015 01:46 PM
SergheiS
Sep 29, 2015 08:56 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
