How loud are roller tiped rockers supposed to be??
Old May 18, 2003 | 12:43 PM
BOWTYDE's Avatar
I just got my car back with 1.6 Roller Tiped rockers (not full RR) and my cc305 cam. I haven't gotten the car tunned yet for the cam but it dosen't seem very fast, The tires don't even burn when I floor it (like they did before cam and rockers). I'm thinking that the valve aren't adjusted right and this could be the main cause of my problem. My question is, How loud are they supposed to be? I know they are supposed to be louder but, these sound as loud as stock rockers do when they are loose, I can here them out side the car with the hood down......
Old May 18, 2003 | 01:41 PM
slopokrodrigez's Avatar
The noise you hear is either out of adjustment or not pumped up yet.
You have to give the lifters time to pump up. You also want to be sure to preload them correctly. when the ex valve is just opening, adjust the Int valve by loosening the nut until the push rod spins freely. then tighten the nut until you feel drag on the push rod. then tighten the nut 1/2 turn more.
Then adjust the ex valve when the int valve is is just closing. Use the same method as you did for the intake valve. Do all the others the same way.
Old May 18, 2003 | 01:46 PM
GEES97TA's Avatar
I have full roller rockers i dont hear them that much,if that help's you at all.
I was told you shouldnt really hear them.
Old May 18, 2003 | 02:23 PM
BOWTYDE's Avatar
How long dose it take for the lifters to pump up?? I have put about 300 miles on it and they are still loud....
Old May 18, 2003 | 02:45 PM
Lunarson's Avatar
Mine chatter just a little but nother major, I adjusted mine with the motor running so I'm fairly certain their dead on ***** accurate.
Old May 18, 2003 | 02:55 PM
My full roller Comp Pro Magnums are "clicky". Even with the LT4 valve covers, I can tell they are there.
If you are low on power, you may have your preload too tight. Loosening them will not make the rockers quieter, however.
Old May 18, 2003 | 04:05 PM
Joe Brodman's Avatar
GP Moderator
Really? I have the 1.6 Comp Pro Mags, 7/16" studd, Crane guideplates. Mine are SILENT.
My adjustment method was doing it while she was running; tighten it until it stops chattering, and about a 1/2 turn more. I too have the LT4 composite covers, and I took one off (for another reason) and had the car running, and had others comment how quiet my rockers were, even with the valve cover off.
Old May 18, 2003 | 08:25 PM
BOWTYDE's Avatar
I don't believe mine have a preload adjustment, they look just like the stock rockers but with roller tips and have a 1.6 ratio to them....
Old May 18, 2003 | 11:52 PM
hot936spd's Avatar
how do you like the cc305 cam, whats your new times with the cam thanks
Old May 18, 2003 | 11:57 PM
thewinner's Avatar
my 1.6s are dead quiet. lt1 stock Valve covers.
Old May 19, 2003 | 08:01 AM
When you go to zero lash and then add 1/2 turn or whatever, the 1/2 turn = preload. It's not something on the rocker.
Old May 19, 2003 | 08:30 AM
All_Z_Way's Avatar
I have the Comp Pro Mag 7/16 stud non-self aligning rockers and I do hear them...more so at certain RPM levels, but they are not very loud.
Old May 19, 2003 | 09:47 AM
wile2k's Avatar
Re: How loud are roller tiped rockers supposed to be??
Well, kinda chiming in a bit late but... I have Crane Gold Race RR and they are a bit clicky but definatly not near as loud as what you are describing. If yours are as loud as you are making them sound then I'd suggest you get under there and check around. Check the valvetrain geometry, maybe your rocker is hitting the stud (maybe too short pushrod <I had that problem>) worst case, or maybe just encountering interferance with the valvecover better case. Either will make it much louder than it should be.
Anyway, if it is that loud then your knock sensor is probably going nuts, and thus a significant loss of power as you describe (probably pulling max timing allowed by the PCM due to significant "knock" heard).
Good luck.
Old May 19, 2003 | 09:54 AM
PNYKILR's Avatar
From: Albuquerque,NM--5,600 feet above you sea-level cats
I f I were you I'd stop driving it, untill you get it fixed. No since in making things worse. I would know.
Old May 19, 2003 | 04:16 PM
BUBBA's Avatar
Mine were really noisey after 1.6RRs. I heard that RRs were more noisey. That's one reason Lt4s have less sensitive KMs because they have RRs.
If, however, you are hearing loud knock when the hood is down or when you are inside the car, I'd check for adjustment or lifter needing some pump up.JMHO
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
94Form
Jul 17, 2015 10:56 PM
Boss002
Jul 9, 2015 03:33 PM
mrwz28
Jul 8, 2015 09:11 PM
