how long until retorquing header bolts?
Old Apr 19, 2004 | 07:11 PM
scoobysnax83's Avatar
Old Apr 19, 2004 | 07:17 PM
95_LT1_6SPD's Avatar
i do it within the first 2-3 days, make sure to get things nice and hot and then do it. ( after it cools down to the touch ) Do this twice, and you should be set.
Old Apr 19, 2004 | 07:19 PM
HardcoreRM125's Avatar
A few heat cycles ... Then once again in a few weeks I think ... Check them though to see if any look like theyre working loose I guess , Better to retighten them too much then not enough and blow out the gaskets
Old Apr 19, 2004 | 07:22 PM
I'm just afraid of breaking them. I am quite a brute So get them nice and hot then cool to the touch and tighten. Do this 2-3 times and I should be good?
Old Apr 19, 2004 | 07:38 PM
bdc95ta's Avatar
yup!
..if your afraid of snaping the bolts just use a torque wrench!
-b
Old Apr 19, 2004 | 07:41 PM
teke184's Avatar
what's the proper torque setting?
Old Apr 19, 2004 | 07:48 PM
gb95zconv's Avatar
Originally posted by bdc95ta
yup!
-b
lol.....how do you get a torque wench in there.....its all I can do to get an assortment of small wrenches on my header bolts.
Old Apr 19, 2004 | 09:03 PM
rskrause's Avatar
Moderator
With modern gaskets and proper machine work it's not necessary. Do you think the factory does it? Not to say that everything the factory does is right, but how many new cars have problems related to improper head bolt torque? If you feel compelled to do it, a couple of good heat cycles is what we used to do. And yes, if your are going to do it use a torque wrench or you will do more harm than good.
Rich Krause
Old Apr 19, 2004 | 09:53 PM
hsyr's Avatar
Rich Krause
But how do you plan on getting a torque wrench in there like the passenger side? I use about 3 different sizes of wrenches to do the job.
Old Apr 19, 2004 | 10:02 PM
Calibrate your arm to 26 lb. ft. and tighten away!
Old Apr 19, 2004 | 10:11 PM
you're making up a number, right? If 26 ft/lbs is the tq setting, then damn. I'm screwed, lol
Old Apr 19, 2004 | 10:49 PM
26 is the number from the "bible". Doesn't seem like much, does it? Remember, this is an aluminum head you are screwing into.
Old Apr 19, 2004 | 10:51 PM
well, I know I'm over that, so I'm just gonna leave things alone
26 just doesn't seem like enough at all... You tq the intake manifold bolts tighter than that
wait, maybe I'm thinking head bolts...
Old Apr 19, 2004 | 10:54 PM
Yeah, the intake's are 35.
Old Apr 20, 2004 | 04:42 AM
rskrause's Avatar
Moderator
I was thinking head bolts, DOH!
But I don't retorque header bolts either, unless they are leaking.
Rich
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
maybe2fast
Mar 16, 2015 09:45 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
SavageZ28
17
Jul 14, 2002 11:04 PM
