How long can cylinder heads sit before needing a freshening?
Old Feb 15, 2008 | 02:46 PM
Tokuzumi's Avatar
I have a set of LT1 cylinder heads (AFR 190s, I believe) that I acquired when I sold some car parts. The heads were not used. I received the heads in 2002 (June, maybe), and I have had them in the box they were received in. How long could the heads sit before the springs would need to be re-done? Thanks.
Old Feb 15, 2008 | 04:02 PM
ss.slp.ls1's Avatar
I'd say the are totally fine, just put some lube on all the moving parts, and you should be good to go.
Old Feb 15, 2008 | 04:04 PM
96capricemgr's Avatar
Did the valves or hardware rust?
I would have the springs tested and replace the seals.
Just be aware those are not good heads anyway, best thing you can do is sell them.
Old Feb 15, 2008 | 06:27 PM
97ChameleonTA's Avatar
Moderator
Why exactly are they not good heads???
Old Feb 15, 2008 | 06:32 PM
Lack of positive results.
Old Feb 15, 2008 | 06:35 PM
mdacton's Avatar
whats a positive result?
I know 2 people that have them.......not the greatest but 11.0@ 120 on a stock bottom
Old Feb 15, 2008 | 06:37 PM
LT1s NA with these OLD castings?
Old Feb 15, 2008 | 06:38 PM
mdacton's Avatar
yep, but they were built long ago and just bracket cars.......
Old Feb 15, 2008 | 07:13 PM
Moderator
I can confirm that an 'old' set of AFR 190 LT1 heads went well into the 9's on Dave Deluca's nitrous car. I've also seen an LT1 TA run 10.5's on 4lbs. of boost with the same heads.
Again, how are they not good? Lack of positive results just means they weren't popular (read expensive) back then or people that ran them weren't posting their results on the internet....
Old Feb 16, 2008 | 09:35 AM
thebufenator's Avatar
were those results with ported heads, or as cast?
Old Feb 16, 2008 | 10:34 AM
Kevin Blown 95 TA's Avatar
I doubt anybody runs them 'as cast'. That is just for someone who wants to have them ported by someone else and not AFR.
Old Feb 16, 2008 | 12:57 PM
red94chicken's Avatar
are you looking to get rid of them?? what size chambers?
Old Feb 16, 2008 | 01:49 PM
If you say so but the results I have seen are FAR FAR from that. Like a heads and cam f-body running what my cam only car ran.
Porting changes things and I am sure there are porters who can make them work but generally it is not worth the effort.
oldschool
Feb 9, 2016 09:21 PM
Jazsun
Dec 29, 2014 12:14 PM
Elcojoe
Nov 17, 2014 10:27 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
