How long to break in clutch?
Old Jan 24, 2003 | 12:30 AM
kgkern01's Avatar
Just got tranny rebuilt and new Spec Stage 3 Carbon disk installed, how long to break in clutch? I heard only 350-500 miles, is this right?
Old Jan 24, 2003 | 12:33 AM
LT1derful's Avatar
I'd say at the VERY least 300. Most clutch companies require 400 in order to be "under warranty".
I have my Spec Stage 2 about 350, then starting taking it to the higher RPM ranges...but not in every gear. After 400 miles, I started from a dead stop and hit 6K RPMs thru 3rd gear...she grabbed like MAD!
But, here's what I did, if you want some advice that is. When I first got it, I shifted at 2500...after 100 miles, went to 3000 RPMs, 200 and 300 miles, I didn't go higher than 3500 RPMs.
Basically slowly introduced the clutch to higher revs.
DJ
Old Jan 24, 2003 | 01:48 AM
bunker's Avatar
i always thought you just hammer it while new hehe guess I was wrong.
Old Jan 24, 2003 | 07:57 AM
xxsaint69x's Avatar
hmm same here
Old Jan 24, 2003 | 11:16 AM
KWKSLVR's Avatar
S.E. Region Moderator
Give it 500 miles before you start launching off of it. Take it to redline if you want, thats not going to make a difference. The main thing is to let the material seat (500 miles) before you dump the clutch. Drive the **** out of it though. It'll be fine.
Old Jan 24, 2003 | 01:07 PM
hsyr's Avatar
I heard that if you get the disc material made with ceramic you don't need to break it in. Is that right? Or what?
Victor Lamb
Aug 26, 2017 02:52 PM
Queens94z28
Mar 23, 2015 08:06 AM
HectorM52
Jan 30, 2015 11:08 PM
