How long before starting motor after intake install?
I apply the RTV then let it get tacky(20mins) I then set the intake ontop of it and go ahead and torque the bolts down to spec in order..I go ahead and put everything else back on and wait about 1-2hrs then fire her up..hasnt failed me the last 5 times..
Cody
Cody
Cody
Cody
While it is probably a good idea (since Permatex recommends it
) to wait 24 hours to cure, I haven't had any problems cranking it right on up w/o any wait. It takes me about an hour or so to get from laying the intake on the block to putting the key in the ignition.
Ryan
) to wait 24 hours to cure, I haven't had any problems cranking it right on up w/o any wait. It takes me about an hour or so to get from laying the intake on the block to putting the key in the ignition.Ryan
Man with all these posts you'd think you were trying not to blow up your new motor
!!!! j/k bro
I'll prob. stop by sometime today with the pump, not sure when since it's almost 3:30am and I just got in
Oh, lemme know if you need some of the Permatex Ultra Copper, I went alittle nuts lastyear while doing the trans. rebuild and intake leak fix and bought a few extra of these, and the black stuff too.
Dave
!!!! j/k broI'll prob. stop by sometime today with the pump, not sure when since it's almost 3:30am and I just got in
Dave
Cody
Cody
For the original poster I would wait 24 hrs for full cure. Also I used Permatex "THE RIGHT STUFF" and it has not failed me in at least 45K or so which is about a year or so.
formula218
Dec 2, 2014 04:27 PM
Jul 4, 2005 05:00 PM
