Bearings on driveshaft too big?
Old Apr 25, 2003 | 09:13 PM
96z's Avatar
96z
I went to put in my 1LE driveshaft today and the bearings on the driveshaft are too big to fit into the 10 bolt. I compared these bearings to the stocker and they are considerably bigger...I then tried to get the stocker bearings on the 1LE driveshaft and they are too small.
Anway I can fix this??
Old Apr 25, 2003 | 09:15 PM
scoobysnax83's Avatar
Rock ? Hard Place ?
Good Luck, Bud!
Old Apr 25, 2003 | 10:05 PM
The stock u-joints are 1310's. Sounds like the 1LE units might be 1320's. If that is the case, you will need a "cross-over" u-joint to attach the 1320 driveshaft yoke to the 1310 pinion yoke.
Old Apr 26, 2003 | 02:18 AM
Prince's Avatar
You may also be able to take it to Univervsal Joint on Walden. When I did the T-56 swap, they were the one's who balanced it and put new U-joints on. All for $20 too.
Dave
Old Apr 26, 2003 | 10:22 PM
96z's Avatar
96z
Injuneer....thanks for some actual numbers Ill take a look into those sizes...
Ill check that place out too dave.:
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
gomaro
Events and Cruise Spots
May 6, 2015 09:02 AM
ddr698
Jan 31, 2015 10:58 AM
