how to know if geometry is correct (pushrods, valve train)
Old Aug 8, 2004 | 02:09 PM
Fbody1's Avatar
I currently have crane 1.6 rr , thinking on getting some scorpion 1.7 rr, should I be worried about the valvetrain geometry ? and how do I check it? I have the hotcam now I think that the lift should be .556w/ 1.7 am I correct ? thanks
Old Aug 8, 2004 | 10:11 PM
Fbody1's Avatar
Re: how to know if geometry is correct (pushrods, valve train)
anyone ?
Old Aug 8, 2004 | 10:57 PM
Buttercup's Avatar
The only way to be sure is to visually check the geometry. The rockers need to be centered on the valve stem tips. They also need to sweep across the center of the tip when run through a full lift cycle. A dab of thick assembly grease works good to see where the rockers sweep across the valve.
AdsoYo
May 2, 2018 03:21 AM
LimitedEd1LE
May 18, 2015 01:24 PM
carl.froehlich
Mar 13, 2015 12:38 AM
Jazsun
Dec 29, 2014 12:14 PM
