how to keep rear differential from leaking???
Old Jul 8, 2003 | 02:58 AM
cals400ex's Avatar
i did not have any problems before i change to synthetic. now my differential leaks between the cover (girdle) and the differential. i first tried just a gasket. second time i used two thin bands of rtv silicone sealant on both sides of a new gasket. i torqued the bolts in a criss-cross pattern to 22 ft/lbs both times. my girdle is clean. actually i just got a new one before i did this the second time. maybe i should try a little sand paper on the differential??? i cleaned it off to where there is no gasket or sealant on there. any suggestions?
Old Jul 8, 2003 | 04:06 AM
revtime's Avatar
Indian Head Gasket Shellac.
I just did this and no leaks at all.
I had a bad leak before and that stuff seems to have cured it.
Old Jul 8, 2003 | 04:39 AM
TobyZ28's Avatar
I'm in the same dillemma as you. I just redid mine "again" with synthetic... looking under the back yesterday i noticed it was leaking AGAIN! I can't figure out what im doing wrong, the last time i did my differential i made very sure that the surface was super super clean and that every bolt was done tightly...
Old Jul 8, 2003 | 06:59 AM
97FormulaWS-6's Avatar
*shrugs*... Mine seals fine.... with just a gasket... no RTV...
Old Jul 8, 2003 | 09:01 AM
Gripenfelter's Avatar
Are you guys sure its not coming out of the pinion seal?
Mine leaked from the pinion seal not the cover when I switched to synthetic.
Old Jul 8, 2003 | 11:21 AM
TobyZ28's Avatar
My god jim that must be it! How can you fix the pinion seal?!
Old Jul 8, 2003 | 01:25 PM
ChickenScreamer94's Avatar
my car has always leaked from the pinion seal. I even had it replaced. It just came back. IMO just leave it alone unless it is leaving more than just a drip a day. Just keep an eye on the level of fluid. DO you have the stock driveshaft? I think the vibrations wore the seal out
Old Jul 8, 2003 | 01:56 PM
FireAm94's Avatar
I had a slightly warped vibeshaft and it caused my rear to leak at the yoke. Replaced the yoke and pinion seal and never had a problem over the 2 years after that.
Joe
Old Jul 8, 2003 | 01:59 PM
InjectedSS's Avatar
mine leaks from the pinon seal as well and theres NOTHING YOU CAN DO ABOUT IT! ive had my rear end redone 4 times since ive owned my car and i just know now that the 10 BOLT is the BIGGEST PIECE OF SH*T that i own those rat bastards at GM for putting that GHEY thing in f-bodys
Old Jul 8, 2003 | 02:34 PM
FireAm94's Avatar
Did you try replacing the yoke?
Old Jul 11, 2003 | 12:48 AM
cals400ex's Avatar
you wouldn't believe how dumb i am. i think mine was just leaking out of the drain bolt on the new TA performance girdle.
Old Jul 11, 2003 | 03:17 AM
revtime's Avatar
Mine was leaking at the drain hole too.
A dab of RTV and put it back in and no leaky.
Old Jul 11, 2003 | 03:35 AM
SilvercamZ28's Avatar
Mine also leaks from the gaskett.. ever since I installed the 3.73 gears.. and T/A diff cover... it maybee leaves a drip every other day.. so I just don't worry about it,
Old Jul 11, 2003 | 03:44 AM
revtime's Avatar
Make sure you don,t let the level get too low or you will have big broken rearend problems.
If you can find it the Gasket shellac is awesome.
Got a mechanic friend who said "You wanna stop the leak? use this stuff"
He was right.
Old Jul 11, 2003 | 09:25 AM
FireAm94's Avatar
As long as the plug is fully installed under no circumstances should it leak. They are pipe thread are they not?
Joe
F'n1996Z28SS
Aug 23, 2023 11:19 PM
QuickSilver02
Apr 7, 2015 11:12 AM
alex5366
Feb 17, 2015 10:43 PM
Sixer-Bird
10
Aug 25, 2002 01:12 AM
