how to install water pump seal
Old May 27, 2008 | 02:13 PM
  #16
Mr_Bond's Avatar
Originally Posted by race u 2
I was just wondering if there is a seal installer to install the water pump drive shaft seal that is in the timming cover I tried to install one today with no luck it pushed the inner seal to the out side dose gm make a seal installer for this seal or what have you guys been useing to keep from folding the inner seal in
Kent-Moore make the tool, if you feel like paying for it.
J-39087 Driven Gear Front Seal Protector
Old May 27, 2008 | 02:31 PM
  #17
ChevalierSS's Avatar
as mentioned, I just used the coupler without any problems
also from my experience if you tear it just a little bit, it will leak like the Titantic
Old May 27, 2008 | 02:51 PM
  #18
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
Originally Posted by shoebox
I just slide the seal over a socket.
This is also what I did. I'm not sure what size, or brand of socket it was, but it was a deep well just slightly larger than the shaft. I oiled up the socket, and it worked great. Once it was off the socket, and on the shaft, I just pecked it into place with a small hammer.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
