how to install serpentine belt step by step?
Old Nov 1, 2006 | 06:01 PM
Haskin Z28's Avatar
been a while since ive worked on my car..a real while..anyone have step by step instructions with possible pictures on how to isntall serpentine belt..thanks
Old Nov 1, 2006 | 06:25 PM
OBE1 95Z28's Avatar
I believe there's a graphic on the radiator cover plate showing the routing of the belt. The belt has a spring loaded tensioner arm down next to the AC compressor. Using a long arm ratchet and a 13mm socket, you can move the tensioner to loosen the belt to remove and replace.
moparman's Avatar
This is one of the easiest things to do on an LT1. It'll take longer to jack the car up than it does to change the belt. Jack up the car and safely support it. Get ratchet and socket, IIRC it's a 1/2 inch. Put socket on bolt on adjuster pulley. Move the pulley so you take the belt off. If you forget which way the belt goes, check the diagram on the radiator cover.
Old Nov 1, 2006 | 06:32 PM
TobyZ28's Avatar
I'd be impressed if you could put it on incorrectly even without the diagram The only thing you need to do is make sure the belt is fully centered on each pulley...
Old Nov 1, 2006 | 07:05 PM
Release the tensioner (13mm) and slip the belt off. Follow the diagram on the radiator cover for putting it back on. I slip it on the crank pulley last for install.
Old Nov 1, 2006 | 08:01 PM
00JoeZ28's Avatar
Listen to this guy, he knows what he's talking about!!!
Hey Shoebox, thanks for your help in the past man, the website is really what I needed to get my motor back together.
Nov 18, 2023 07:21 PM
Victor Lamb
Aug 26, 2017 02:52 PM
grabbem88
Feb 23, 2015 09:41 PM
Sandersen511
Jan 13, 2015 03:49 PM
