How to install MOROSO CAI?
Old Oct 21, 2004 | 06:02 PM
Kurt Crosbie's Avatar
I'm having lots of trouble with this. It just will not go down to where its supposed to. What do I need to do? Anyone else have trouble with this?
Old Oct 21, 2004 | 06:04 PM
Z95m6's Avatar
Re: How to install MOROSO CAI?
I had a K&N CAI and i believe you had to move or do something diff on the TA's because they have some headlight electical stuff in the way. I've never seen a TA but i remember it saying something in the instructions about it.
mattybz28's Avatar
Explain your problem better.. What's not fitting?
Old Oct 21, 2004 | 06:09 PM
ulakovic22's Avatar
He's right, you have to relocate the electrical wiring that runs to the headlights. It has to be moved back next to where the fuse panel and ABS stuff is so it is out of the way.
Old Oct 21, 2004 | 06:54 PM
I don't want to mess anything up. Those wires you have to move are pretty stiff, and I didn't want to unlplug them and screw something up.
Is that big set of wires all I have to move?
Old Oct 21, 2004 | 07:08 PM
ulakovic22's Avatar
The instructions read as such: On Firebird/TransAm models the headlamp control module is located on the interior air duct. It is to the right of the air cleaner ***. and is retained by a plastic push clip. Slide a screwdriver between the air duct and the sheetmetal and pry upward and remove. Disconnect the wires from the module and set aside for re-installation later.
Once you have everything put together you need to test fit the module on the inner fenderwell in an appropriate place and mount it using the double sided adhesive and then reconnect the module wires.
Old Oct 21, 2004 | 07:43 PM
bt96ss's Avatar
Throw the instructions out. Heres how I did mine. First I mounted the metal plate. Then put the plastic portion from mass air to plate on. Then I found it easiest to go ahead and take the rain guard off and put the filter on from the bottom. There is no way you can manipulate the filter in and get the plate bolted down. I tried just for kicks once and it was crushing the filter. Then I just used a long sef tapping screw to mount the headlight module. Hope this helps.
Old Oct 21, 2004 | 09:17 PM
Antz97ZNJ's Avatar
Im the last thing from a mechanic here and I had little trouble installing my moroso cai on my 96...Its doesnt get anymore cut and dry...just be careful you dont install the plate upside down.
troywg
Sep 12, 2002 07:28 PM
Teal94V-6
Aug 31, 2002 09:21 PM
TheV6Bird
Aug 27, 2002 10:38 PM
jim88iroc305
Aug 13, 2002 09:24 PM
kurob25
Aug 5, 2002 08:03 PM
