how important is it to get the LK4 after 1.6's
Re: how important is it to get the LK4 after 1.6's
its not that important
the LT4 KM is less sensitive to picking up false knock and then retadring timing resulting in a significant power loss
if you get a mail order tune tho this issue can be dealt with while using the stock KM and getting some other things done at the same time for a little bit more money
I've heard this several times but on a 93lt1 how would you solve the
the problem if you change to 1.6 rr i was thinking about doing the change but i was un sure if it would make a difference
