how to hook up a shift light??
Old May 1, 2003 | 02:27 AM
DTABFORMULA's Avatar
i have a 93 formula lt1 6 speed and i bought a shift light nad the directions are retarded.. i know one wire has to go to the coil right?? which wire on the coil does it go to?? my coil has like 4 wires going in it.. anything would help thanks
Old May 1, 2003 | 08:47 PM
Bud M's Avatar
I used the pink/black wire on the tach. You can also use the tach wire at the PCM.
Old May 2, 2003 | 01:34 AM
what wire should i use at the pcm, do u know which one it is??or color?
Old May 2, 2003 | 06:15 PM
$hawn's Avatar
Isn't the tach output wire white?
Old May 2, 2003 | 06:31 PM
Blue89Bird's Avatar
white wire on red connector
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
phantasm99
Aug 28, 2002 11:01 PM
Krab
Aug 5, 2002 12:08 AM
